Morning all ! Just finished my 1.5 hours full body workout [emoji15]
Is there any girls that I can chat with in this forum?
Or can Lachy just put a dress on and pretend to be a girl [emoji28]
  • Like 1
Sydney ! Miles away ! Don't think she want to drive up all the way from there for girly catch up [emoji41]
Awwwww , I like beautiful legs ! What's your girly name ? Put on your dress and we can catch up for hot chocolate sometimes ok [emoji6]
Had a chat with Paulie this morning, gonna have a catch up this weekend.
His wife Lauren used to be on here years ago but not anymore.
Paulie ? As in Paul and his wife Lauren?
So no more girls from perth on here then ? [emoji22]
The only chick I know from SAU is Dif, she lives in Sydney though.
FYI I have great legs that look wonderful in a dress ;)
Gee you have a short memory...
Yep good pair of stumps that's for sure ;)
When do you reckon you and Corey can come up for BBQ?
Talked this morning, he said 2-3 weeks out should be fine. I should be able to do sat 23rd if my parents can look after the monsters.
Suit you? What were you thinking of doing?
Blonde, teacher, black 33
Is it coming back to you?
Oh! I've met her :P
23rd would work for me.
Drinks and this place - http://www.oldfaithfulbar.com.au/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
