Been a long time since I've had to ask for any assistance from this forum but was hoping someone might be able to give me what they think the noise in the video could be.
Basically I've done a timing belt change, new tensioner & idler pulley & new water pump (gates brand). I don't think I over tensioned anything - the TB was tight to get on but figured that would be the case for a new TB. All timing marks lined up as per the instructions in the service manual & old mates tutorial on how to do it. With my head down near the cams the sound definetly sounds like it's coming from under the cam cover - or could be from the front of the car somewhere (possible alternator bearing?)
Any help on the topic is greatly appreciated.
Cheers!
trim.981641ED-F8C3-4985-B83D-7B163BF7E5FD.MOV
Edited by BstewyR33
https://www.sau.com.au/forums/topic/456743-engine-noise/
  • 3 weeks later...
Just as an update - I left the TB as it was tension wise to investigate the whining noise being something else.
After doing the old metal pole onto the alternator, water pump, power steering pump, ac compressor and listening for any sort of noise - I couldn't find anything abnormal from any of those.
Searched for any information on bearings that run off those belts and came to the conclusion it was the AC tension pulley. The main reason coming to this conclusion was that the noise didn't get loader on turning the steering wheel - cancelling the PS pump. It was any loader on start up or general running - cancelling out alternator and TB, it didn't get any louder when turning on and off the AC - cancelling out the compressor. The only bearing left was the tension pulley.
Pulled it off - could hear that was rolling ruff ( when you hear what a new bearing sounds like - you know the sound it shouldn't make)
I swapped this bearing out and no more whining sound, which I'm cheering about!
The bearing itself was $7 from bursons (6301)
The video is after everything the new bearing has been fitted to the pulley - no whining noise
IMG_0135.MOV
Edited by BstewyR33
https://www.sau.com.au/forums/topic/456743-engine-noise/#findComment-7544677
Cheers lads, yea a cheap fix & cheap win for sure.
Got quoted for a Genuine compressor from Japan - $2000ish
A company on the Southwest of Brisbane had O/E for $695 or aftermarket for $595
A shop wanted to charge around $1400 to degas, rebuild, fit & regas.
https://www.sau.com.au/forums/topic/456743-engine-noise/#findComment-7544744
Was that shop in brisbane quoting for a replacement comp that was genuine or just one of the well known brands? I think mine might die soon so keen to see what options i have comp wise. Ive quoted oem ones at the same price from Japan. Bit rediculous lol
https://www.sau.com.au/forums/topic/456743-engine-noise/#findComment-7544766
A/C compressors are much of a muchness. They do the same job, I certainly wouldnt go out of my way to source a Nissan compressor when an equivelant replacement can be had for 1/3rd of the price
Thanks for posting that, hopefully I wont need it but will be a good reference if I ever do :)
https://www.sau.com.au/forums/topic/456743-engine-noise/#findComment-7545407
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
