Hi All,
Wanting to know if anyone has direct experience/ knoweledge on pon-cams..
Specifically if PN# 143021 264/264 duration 8.5mm lift will run in an rb20/ r32rb25de head?
They are listed as suitable for R33 rb25det up until '97 manf date.
But confilcting info on the web is rife and i cant find a clear answer.
- Some say theses cams aren't compatible with VCT in the rb25dets that they are listed for.
(Thus making them quite suitable for the rb20dets).??? this may be BS??
I am looking at these cams for my rb30det build (using r32rb25de head), but not sure if these
would be compatible with CAS etc.
Thanks for any help-
https://www.sau.com.au/forums/topic/456976-tomei-pon-cam-question/
I don't see the headache...
Just need to know if anyone has fitted poncams that are supposed to be for r33 rb25det's into an rb20det?
You need to sit back and realise what you're asking.
First you say you're building an RB30DET using an R32 RB25DE head and want to know if R33 Poncams will fit. Then you're asking about it going into an RB20DET.
What do you want to do? Put the cams in the RB25DE head or RB20DET?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
