Just got my first gtr and went to change the air filter and saw that it has oil around the rim and the air flow meters have oily residue on then and pipes leading to turbos had some oil in them .
Can this cause problems with the turbos if they have been sucking in the oil???
Any help would be appreciated .
https://www.sau.com.au/forums/topic/458176-oily-air-filter/
I'd spend the time to pull all the turbo side piping off from intake to inter-cooler to have a look and see how much gunk and shit has been collected and might be worth cleaning it all up.
Obviously the lowest points in the pipework will collect/pool all of the oil over time.
As Hadouken said, you should invest in a Catch Can. Preferably one that will work and not just put the shit back into your intake if you plumb it back, or send it to an external filter.
https://www.sau.com.au/forums/topic/458176-oily-air-filter/#findComment-7566687
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
