BWCP last Saturday Night
Guest Variable
My girlfirend and I were staying down the coast on the weekend so after dinner Saturday night we thought we would check out the car park. We took the entrance near the pool and as we rounded the last corner, the boys in blue were waiting there. They had a couple of VL commodores pulled over and stopped to check my license and have a look at my car. Happy to report they found no issues and even said "nice car mate, have a good night" as they waved me through.
The guys in the VL's had about 6 officers going over their cars with flashlights.
Didn't see any skylines in the carpark at all.
Hopefully no one from here had any problems.
https://www.sau.com.au/forums/topic/45819-bwcp-last-saturday-night/
I actually like to see the coppers doing random breath tests and licence checks either on the way in or out.
We've been in there a few times when they've done random breath tests on the way out and quite a few people have been caught.
I wish they'd breath test the stupid little 15 year olds that go down there and get drunk every weekend and make smart arse comments or make fools of themselves.
It'd be worth copping a blowie off those stupid 15 year olds just for the 5 minutes of silence.
now now thats a bit bellow the belt there man ;) + probly that smashed too 2 & a half mins into it they would forget what they were suckin on & bite it off :Oops: :usuck:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
