Have two rb25 engines in pieces. Was going to rebuild into one good one but lost motivation. Parts are Ono.
Good rb25 head. Complete with cams, covers, cam gears (random adjustable intake gear) Bolt onto a 30 bottom end and away you go. $200
Average rb25 head. Gunky needs a clean and check. Comes with cams, no covers or gears $100
Rb25 block x 2. $50 each
Rb25 crank x 2. $50 each
S1 standard coilpacks with loom and brackets. $100
Rb25 sump x 2. $30 each
rb25 oil pump. $40
Rb20/25 exhaust manifold x 2. $50 each
rb25 inlet manifold. Complete minus injectors. $50
S2 rb25 arm. Worked great, upgraded to z32. $80
Rb20/5 cross over pipe with bob. $50 each
Turbosmart boost T $30
HKS SSQ bob. $30
Gktech s13 extended lower control arms. 9 mm longer over standard s13 arms complete and less than 500km use. Great for a track cars to get the extra track. $250
Gktech 4-5 stud 15mm conversion spacers. $80
Rb25 short shifter. $50
Hr31 weather shields. Awesome condition for their age. One slight crack in the plastic, clips still intact. $400 firm
Can get picks on request. Can post smaller items at buyers expense. Located in SA in the Adelaide hills.
Pie me for more info.
Cheers,
Adam
Hi, Adam
Will take the RB25 short shifter,pm u to get your bank details and postage cost to my workshop at Braeside Vic 3195
please call Alex 0433878905
  • 3 weeks later...
  • 5 months later...
  • 7 months later...
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
