Hey all
Ive recently picked up a heap of crap 32 gtst as my daily car.
Ive had a few quick dailys, couple 33 gtrs etc. But now im after a less detectable car. Especially since i have a track 33 now to. But i still like buying stuff and modding my cars.
So this time i was thinking instead of buying performance parts and what not, just get it to a nice 180kws for the road and do it up more umm showy.
And no i dont mean bright purple with chromies and doors that open up.
I mean more of a custom paint job nice body kit etc
My question is, are there any show and shines / car shows around these days??
Havent seen any mentioned in ages? Not like 5 - 10 years ago anyway!
https://www.sau.com.au/forums/topic/458291-adelaide-shows/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
