I'm sure the dyno sheet would only tell half the story of how this thing behaves. Drive it through the hills with its tricky diffs and sticky tyres and it would be an absolute bullet. E85 and give it more boost through the middle would fatten it up even more but I'm not sure how much the peak figure would change.
Definitely want a drive!
  • Like 1
Wish the speed reference was revs instead easier to read, anyone able to give rpm reference points?
That run would have been done in 3rd gear.
That's 22.5 km/h per 1000 RPM. (Close enough when factoring in tyre sizes)
90 km\h is 4000 RPM.
Why would anyone use 3rd, not even wheel/ tyres would simulate a proper 4th gear pull.
Wouldn't those dots on the map represent rpm points?
Last dot meaning 8k?
Edited by mr skidz
Out of interest, what makes you say it is in 3rd gear?
Because the dyno run went to 180 km/h which is the top of 3rd in a factory geared box. It's making peak power around 160 km/h which is 7000 ish RPM. If it was in 4th it's peak power would be like 5500 RPM (rough calcs) which isn't right.
Hmmm I just look at it again, I'm an idiot. Thanks.
  • Like 1
I agree.
Real world experience In this car would be the only true testament.
Even if it doesn't make more than 360kw peak it would have such a absolute meaty power band.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
