Happy Laps Lakeside Park - 11/10/2015
Event:
Happy Laps - Lakeside Park
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Breakfast will be served with bacon, eggs, beans and toast.
Lakeside Park
Date:
Sunday the 11th of October
Time:
7:00 AM Arrival
7:30 AM Breakfast
8:00 AM On Track
Cost:
$35 for members
$50 for non members
Please note that this is a per person cost, any passengers are required to pay as well.
If you wish to come along to watch and not have breakfast it is free.
Requirements:
1. Participants must meet minimum age requirements for being on track.
2. The overtaking car is responsible for completing the overtaking move safely.
3. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
4. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
5. Cars should not be more than 2 abreast at any point on the track.
6. Be aware of cars around you, in front and behind (and beside when being overtaken).
7. Do not assume that the car in front of you knows you are there.
8. Please pay cash on the day, no EFTPOS is available.
Lakeside Specific Rules:
10. Participants must have completed at least ONE QR Happy Laps before participating in a Lakeside session. (If you have done other Lakeside events before you may be eligible. PM me to clarify)
11. No overtaking or cars side by side on the kink.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
Attendees:
  1. Cadmoon +1
https://www.sau.com.au/forums/topic/459471-happy-laps-lakeside-park-11102015/
Hi Mike,just transferred $135.
$35 for myself in v35 skyline and $100 for Marty and Donna (non members) in a mx5.
They did a QR Happy laps last year with us and so have qualified to do Lakeside.
  • Like 1
Yes was a good morning guys - thanks heaps.
Sorry I had to bail early - ran out of gas, and had to take the father-in-law home.
Happy with the snot-rocket - was it's first time on track so I was just getting a feel for it. Doesn't go too badly for stock.
Some of you other guys were really hauling ass out there!
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
