Hey guys. Just wondering if I can get some info. I'm after a set of work Meisters 3 piece rims for my GTST. I just wanna know if anybody has them fitted. I want to know if I need to do some crazy mod work to the guards or will they fit okay? I wanna get them in 18s.
https://www.sau.com.au/forums/topic/459517-work-meisters-on-my-r33-gtst/
They only come in 18x9 fronts and 18x10 from Jdm concept. Has anybody bought from there? I'm not sure about the offset for these to fit nice.
I have bought from there. You can get them in any size/width/offset you like.
Leo is great to deal with.
