I'll be getting some new parts installed soon (turbos, cam gears) etc and I was thinking while most of it will be apart how hard is it to paint the rocker cover and maybe the plenum?
I can get the gear needed easily enough (compresser/spray gun), but what do I have to do to each piece to prepare for painting.
Is there any protective under/overcoat I have to apply to the paint to stop it cracking/bubbling from the engine bay heat? and do I have to sand back either items (i guess the cover probably doesnt, but the plenum would yeah?)
Is it a big job to remove the plenum/covers? is it something time consuming and how much would be max I should be charged for the workshop to do it (as I dont trust myself to try)
1 last question, is there anywhere in Brisbane where I could buy the "top secret gold" colour? maybe even buy interstate?
Thanks in advance.
https://www.sau.com.au/forums/topic/45962-painting-rocker-covers/
mate there is a dude on nissansilvia.com that will powder coat ur rocker cover in a wide range of colours. his nik is shakiel or something and heres the thread: http://www.nissansilvia.com/forums/index.p...showtopic=44766
the limited time cost is 100 bux but i think its going up to 120 coz of metal stripping is an expensive process. Plus postage since ur in Brissy and he in melb. Not sure bout the plenum tho...
otherwise if u wanna do it yourself it ain't really that hard. Get fireproof spray paint or engine enamel spray paint doesn't cost that much get a few cans, can get it from autobarn, bursons, repco supercheap bla bla bla. u will need some degreaser as well. Really clean ur rocker cover with degreaser and sanding u don't want any dirt on it as the paint won't stick as good. Then just follow the instructions on the cans and spray away. Do a coat then sand it back then do a coat over it. Keep going with coats till ur happy and thats it!!!
removal: removal of the plenum i dunno. The rocker cover is really easy tho. My rocker cover gasket is weeping at the moment and i will be replacing it soon. When i do i'll write a DIY for it with pix.
best of luck mate,
Rom.
Apparently you cant get a hold of this colour, as topsecreat have the paint code and will not release it, I was looking at painting my car /rocker this colour and could not get the colour code.
However where theres a will theres a way, and i can not garentee my comments, Its just what ive seen and heard.
Just dont wanna give you false information bro :cheers:
FYI and all others please note:
a thread posted in the FAQ/DIY section has to be approved by a moderator and could go unchecked for up to 12 hours (usually not that long) please dont post questions in there and if you see that your thread hasn't gone through dont post the same post again ;)
not lecturing YOU, just informing people here cause not many people read the sticky announcements at the top of the DIY section
cheers all
Jim
Okay, what you need to do is strip it back to metal... it depends on the finish but it cant hurt to get the metal a bit flatter ie sand is back with around 240 wet sand paper.... you will have to primer it first, make sure the primer you use is right for straight on metal as some arent!!! Make sure there is a good build up of primer so a good 2-3 coats... You then need to wet rub the primer with 400 grit for straight colour and with 800 grit paper if you intend to use a metallic... Make sure you dont rub through anywhere, if you do you will need to re-primer.. Then prepsol the area really well and dont get any fingerprints on it or anything else then paint it.... If you need any advice on the rest of the process let me know...
You wont need any special paints or ect automotive paint will stand up to 140 degrees or so and be fine!!!
It is a mammouth task to get the plenum off a gtr while the engine is in the car, do a search on my name and plenum removal and there is a thread where i did it on my r32 while in the car its a tough job but can be done.... the cam covers are pretty straight foword!!!!
Hope this is a help!!!
Daniel
if your covers have no chips in the paint you could get away with a light sand with 400 then paint ect.... if they have chips you can patch primer by rubbing out the chips and spot primering them, then rub the whole lot to get rid of the edges on the primer build up, then paint....
You should primer cause it acts as a bonding agent and you will get alot more professional and smooth looking job....
Also i would rub them back cause they are cast and still fairly rough upon closer inspection!!!
oh and that gold colour you want lucky your not painting a bonnet it isnt the easiest colour to paint on and get an even finish without a spray pattern showing through... lucky your only painting small parts!!!
I used VHT enamel for my purple bits.
All that prep work just sounds like too much hard work... I stripped the factory paint, and gave it a light sand so the paint had something to stick to, cleaned it with thinners, and sprayed the paint (from an aerosol can) directly onto the metal.
yeah but all your purple bits wont last and wont look as good in a few years, and an aerosol can paint job cant look as good as a properly preparred 2pak paint job.... but its cheap and achievable on the other hand!!!!
Another note if you look after the gasket when you take it off and make sure it is clean and totally dry they can be reused easily!!!
The airhorns that can be seen on the left hand side of the engine bay were painted over 10 years ago.
I think 10 years is a bloody good effort, and if I only have to paint it once every 10 years, i'll be happy. :D
Something that hasn't been mentioned, is the use of clear coat.
If clearcoat is used, the heat in the engine bay will eventually cause it to go yellow.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
