Hi guys
This might not be everyone's cup of tea, but I'm just about to start on a rb25det manual conversion into a vs commodore ute. I'm just wondering if anyone has done this conversion on here? I'm wanting to know what specific parts were used, like gear box mount, was a custom gearbox crossmember made? Which sump? Vl k frame etc
Thanks in advance
Taylor
https://www.sau.com.au/forums/topic/459777-rb25det-conversion-vs-ute/
Hi Taylor,
I believe you will require a vl 6 cyl subframe.
There is a power steering and non-power steering version of the sub frame( different rack mounts) available, stick with the ps version and I think the vs rack will bolt up to it.
This should allow you to bolt the engine to the sub frame with factory mounts and sump and bolt straight into the car.
I would look at a lot of vl parts (ps hoses)for the conversion as engine bays are similar .
Cheers
Luke
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
