I recenty had a small fire which burnt a section of the gearbox loom. I've replaced the wires in the melted section and the car starts and runs (no trigger errors). But the manual mode on the gear box won't work and when it changes gears it feels like there is no ignition retard, so it tries to chirp every gear.
I'm assuming the CAN wires aren't fixed properly. Where do all the wires from the gearbox originate from? Is there a pinout diagram for the 3 gearbox plugs. It would make testing the wires much easier if I know the location of the other end.
https://www.sau.com.au/forums/topic/460143-m35-auto-trans-problem/
Yep, the box is in limp mode, no CAN signal so the TPS and AFM signals aren't getting through to the trans ecu in the kick panel. Perhaps the fire shorted the ecu out?
The wiring should be similar to early V35's if that helps, I will try and search for something specific when I get a chance.
I'm thinking that's probably the case. All the wires to the gearbox were melted together (drivers side just under the exhaust), so I would expect that something would have had to give and I didn't find any blown fuses.
Can I just replace the trans ecu? or does it need to be paired to the box?
Yeh Ben, pull the battery out and have a look under the upside down cup, it holds the IPDM module, all the power relays and about 20 fuses. That's where I would suspect the blown fuse would be anyway, the inside fusebox is only for body control.
I tested all the fuses, and they were fine. I've pulled the trans ecu out and I can't see any burn marks. But it could still be damaged. The starter was stuck on when the fire happend, so would would think the current would have been going through the trans ecu
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
