Current mods include
Cam gear (does **** all, gonna set it back to zero when I have a chance)
Exhaust from Front pipe back.
Bleed valve set just before boost cut (12psi?)
HKS front mount
Power FC in cupboard waiting to be installed.
BASS OUT
be differnt go the cams there cheaper and know one does it. I want to see how a stock turbo camed car goes. Would be cool to get mid to high 12's and say yea im still running stock turbo. plus you shouldnt have to upgrade injectors with cams, were's if ya get a turbo, to get a good gain you would have to upgrade to be safe.
260 DEG 9.15mm inlet
260 DEG 9.15mm exhaust
Would these be a worthwhile upgrade os should I go bigger if I was going to buy some????
ALSO, do the R34 GTR cams suit the R34 GT-T
What is the best cam profile for everyday driving and some drag work and drifting and track work.
Cams - while cheap, wont offer a hell of a lot of performance with a stock turbo.
A difference yeah, but when you can make 250-300rwkw quite easily, without doing the CAMS... then it's $$$ that can be spent on things like injectors etc etc
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
