ROBO you got it in one its an upgrade clutch kit for the auto good for around 230-250rwkw
i blew my last auto 6 months after i bought the car, well i didn't blow just wore out the top two gear clutches, happens with auto once ya starting putting more power through it, the box gets weaker, so when i put a new gearbox in i replaced the clutches
i was gonna change to manual, but was $3500 was the best quote at the time found it for $2500 now, but i put another auto in and it cost me around $900 with everything thats including buying the box so i thought that was the best option, 2nd gear is wicked now under full throttle i pull it side ways for a good 1-2 secs if i don't change properly IE i drive it like a manual thats just me
  • Replies 69
You won't get much with a cam gear, maybe 5rwkw!!  I hardly could pick the difference.
I noticed a difference! At the drags im breaking traction in the top of first gear when I launch which I wasn't before the Ex Cam Gear. I'm over it now tho and wanting that next mod :)
A cam gear will cost you about ~$160-180 delivered from Nengun/Greenline. Along with about 1.5hrs of workshop time and its a great cheap mod for less than $300.
Take a look:
i noticed the grunt increased mid-range and it seemed to have a lot more go.. its worthwhile doing.. and for the price especially. Seemed to idle a bit rougher after that, but that may have been the new tune. Unfortunately I didn't get a dyno read out to quantify anything in any proper terms.
hahaa.. its a bit like that.. i got over the whole car, sold it, and now to build a fast one :)
obviously not anything ground breaking, but I just got my PowerFC installed and tuned and i am making 200 at the wheels at 1 bar - this is with 3" turbo back exhaust, ebc, FMIC, air POD and PowerFC. Injectors will be at limit now, so next up for engine stuff will be turbo+injectors+cam gear/shafts.
Its good insurance at anything around 200rwkw to replace the std factory pump (it could be getting a bit tired) and also to add a rising rate regulator to screw a few more kw out of the std injectors.
Remember if only one injector is struggling, (and this may not show up on your dyno analysis) and you are too close to 100% duty cycle, it could easily cost you an engine rebuild.
Hey there
Ive got an auto 96 series II that registered 273.6hp(203rwKw) at 11psi on shout-out mode
probably done more mods than some, cause I dont want to change the turbo or standard ECU
Trust MX cat-back
SS highflow cat
RSR front pipe with stock dump pipe
Apexi filter
TRUST V-SPL intercooler kit
SAFC-II
Greddy Profec B EBC
HKS 256 exhaust cam with cam gears
Bosch 910 external pump mounted inline without surge tank and malapassi FPR waiting to go in
Apexi boost gauge and TOYO RA-1 as well to complete the list
probably will buy a manifold, dump, and intake pipe later and see how much more power the standard turbo can make
good luck with your car though
Hey there
Trust MX cat-back
SS highflow cat
Apexi filter
SAFC-II
Greddy Profec B EBC
That's a very interesting approach, it proves that there is more than one way to skin a cat. Do you have progressive dyno results that you can post? I would really like to understand what makes up the increases. :cheers:
sorry SK, only did one dyno so far and I sorta put everything in reverse order,
EBC first, then SAFC, then FMIC, exhaust and cam last before finally going on dyno
from what I can tell the FMIC felt to make the most difference. I'll post my dyno sheet up soon.
Dont have the funds to change ECU or turbo so I thought I'll do everything else and see whats the maximum safe limit of the standard turbo
Im wondering about the auto trans though, should I start worrying about it?
To answer the questions about the unichip. I have one of these on my manual GTST and they work great. I haven't had any issues with it and I'm making 190RWK at 14psi with the standard turbo. I don't understand why you were told that u couldn't run an EBC with the unichip because that isn't true. I'm running a turbosmart E-boost. The unichip can control the boost if you want it to, however it should only be an option so you should be able to retain the Blitz EBC that you already have installed.
I'm not sure if you can get one for an auto though.....
well every one i have come to a bit of a stop in reaching 200rwkw i took my car along to a dyno day on saturday and it start to ping at 170kw at 6200 rpm boosted at 11psi. now could someone please tell me what this could be could it be injectors and fuel pump or more as yous all know its auto so its a bit hard to get a good ecu. so now i have the problem finding out what it could be so if any of yous have had this problem please let me know what yous have done to fix it well thanks for all ya help and i soon hope to reach 200rwkws after this minor hold up !
Usually this is ignition timing related, but it is easy to tell if it was fuel related via the A/F ratios. If it was going lean then it will detonate. So, did you get an A/F ratio printout from the dyno day? If you did, it will be easy to tell whether it was ignition of fuel. :D
nah didn't get any a/f readings on the print out because it was power runs only i might take it back this week and get it dynoed the other time i had it dynoed it was on 12.5 the whole way so i dunno if it could changed i aint sure so i will take it and see if its not the a/f how can i fix this ?
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
