Hi all,
I have the following items for sale:
2 x HKS GT-RS Turbochargers
Price: $1600.00
Reason for sale: replaced with Garrett -9s.
Dual Blitz Super Sound Blow off Valves
Price: $150.00
Reason for sale: reinstated OEM BoV setup.
GReddy PRofec B-spec II EBC (NOTE: in-car controller only does NOT include wiring harnesses or solenoid)
Price $50.00
Reason for sale: not required for my setup.
All were removed from an R32 GT-R making 305KW. I don't have much detail on these items as I bought the car and it went straight to the workshop to have an engine transplant and the above work performed. The previous owner advised that one of the GT-RS turbos had been rebuilt but I don't have any receipts to confirm this.
Pick up in Melbourne or will post at buyers expense.
Please contact via PM for further details.
Thanks
Bump.....
Also have the following items for sale and will have photos, description and prices up for them soon:
R32 GT-R OEM wheels x 4
R32 GT-R OEM front indicators
R32 GT-R OEM front brake calipers
Suspension taken from an R32 GT-R
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
