Have a '00 RB25DET NEO (S2) in the 260z, have just done a manual conversion and noticed she is running a little bit rough (small squeeling kind of noise coming from engine).
Anyway the car is now throwing a CEL, I went to check the engine codes by shorting out ECU pin 22 to pin 24 (CHK to IGN) to get my check engine codes:
I keep getting code 46 and code 44...
I have checked everywhere and cant for the life of me find what these codes are, i keep finding the codes in the link below repeated all over the internet but there is no mention of code 44 or 46...http://www.sau.com.au/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/
BTW Im reading the long pulses as the first number and the short/fast pulses as the second number.
Here is a video of the light for your own interpretation:
https://youtu.be/J0qQ7u4mImw
Any help would be much appreciated.
Wouldnt you know it, after searching for days as soon as i post the topic i find the answer, for those who find this post searching for answers, here are the codes which i couldnt find anywhere for the R34, enjoy (couldnt figure how to BBC embed the image on this forum):
http://imgur.com/G3jLnQT
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
