As topic states I have a genuine Garrett gtx3071r kit for sale, it has everything needed to fit an rb25.
It has only been on the car for just over 6000kms and is in great condition with no shaft play. I have no use for it now as car is no longer on the road. Originally purchased from MTQ in Wetherill Park.
Kit includes:
Garrett gtx3071r
Genuine Garrett 5 bolt 0.82 AR rear housing with internal waste gate
Garrett 14psi waste gate actuator
Spacer plate to fit to OEM exhaust manifold
All braided water and oil lines
All required bolts, washers, gaskets and hose clamps
Silicon joiner for compressor outlet
Custom inlet pipe with K&N pod filter
Custom dump pipe to suit turbo
Price: $1250 ono for kit
$1100 for turbo only
I'm located in North Brisbane. Pickup is fine and any inspection is welcome.
Can also post at buyers cost.
You can contact me on 0410445935 or PM
Edited by ThirteeThree
Hey mate, turbo was making 288rwkw@20psi on 98 and 335rwkw@25psi on E85.
Only other supporting mods were:
Link ECU
850cc injectors
3" exhaust
Front mount
Hey mate,
Cheapest quote I can find is with couriers please. Postage cost to send everything is around $45.
Extra cover for the lot is an extra $20 if you would like that.
Cheers
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
