Hey guys, got a question. Where are your stock r32 gtst temp gauges are sitting? Recently bought myself a 92 Skyline r32 gtst and its bothering me that temp sitting a bit above the middle, its sitting stable but not sure if its normal to be there or if my engine is running hotter than should be all the time or if the gauge is faulty.
Any input would be appreciated. Thanks
https://www.sau.com.au/forums/topic/461245-temperature/
Thanks lads, how hard is it to get the aftermarket temp gauge hooked up? Or is it just easier to take to a work shop to get that done? Anyone knows how much gauge install would be roughly if it was done in a shop?
https://www.sau.com.au/forums/topic/461245-temperature/#findComment-7643384
Yerh will check out some Youtube stuffs tonight and see whether I got stuff required to get it done at home. Also, does anyone know whats the go this days with gauges and where they can be on the dash without being f***d by police should you get pulled over?
https://www.sau.com.au/forums/topic/461245-temperature/#findComment-7643396
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
