Hey All,
Sam in Radelaide here! Been lurking for a few weeks and now need to get my hands dirty on this great forum.
So me, i am the second owner of a stock but absolutely mint burgundy R31. Its just my daily driver to work and back but as family is getting bigger im looking for a wagon.
Sticking with the faithful Nissan im looking for a 2004 and above nm35 stagea and preferably and axis autech version.
So im on here to browse learn more about the Stegea's and meet some new like minded people in the process.
Cheers all
Nemx
  • Like 2
https://www.sau.com.au/forums/topic/461275-mint-r31-has-been-fun-but/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
