Hi all,
Some more parts up for sale.
4 x R32 GT-R OEM Wheels
Price $500.00 (pick up in Melbourne only)
Reason for sale: upgraded to Alpha Omega Racing EVO Brembo Brake Kit so these will no longer fit
Notes:
  1. A few chips and gutter rash as shown in the photos below.
  2. Tyres are not great (you can have them for free!)
  3. Centre-caps are included
Wheel 1:
Wheel 2:
Wheel 3:
Wheel 4:
R32 GTR OEM Front Indicators
Price: $150.00 (will post at buyers expense or pick up in Melbourne)
Reason for sale: replaced with smoked indicators
Notes:
  1. Includes plastic indicators and bulbs only
  2. Wiring loom and sockets that hold the bulbs in place are NOT included
  3. Tabs are intact
R32 GT-R OEM Front Brakes
Price: $250.00 (will post at buyers expense or pick up in Melbourne)
Notes:
  1. I believe that the rotors are RDA and not the original OEM but not 100% on that
  2. The pads are shot and need to be replaced
  3. I will have the rear brakes available once they have been upgraded to the Alpha Omega Racing EVO Brembo Brake Kit
Please contact via PM for further details.
Cheers
Rob
R32 GT-R OEM Wheels sold pending collection/payment.
A couple more photos and details for the indicators to provide feedback for questions that I have received:
  1. They are in pretty decent condition but that is subjective I guess when compared what you currently have / looking for.
  2. All of the tabs and guides are intact.
  3. The rubber seals are intact
  4. There is a split on the right indicator tab near the screw hole - note that this will not prevent it from being screwed securely into place.
  5. There are a couple of stone chips and a few marks on them
  • 1 month later...
  • 3 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
