Hi all,
Some more parts up for sale.
4 x R32 GT-R OEM Wheels
Price $500.00 (pick up in Melbourne only)
Reason for sale: upgraded to Alpha Omega Racing EVO Brembo Brake Kit so these will no longer fit
Notes:
  1. A few chips and gutter rash as shown in the photos below.
  2. Tyres are not great (you can have them for free!)
  3. Centre-caps are included
Wheel 1:
Wheel 2:
Wheel 3:
Wheel 4:
R32 GTR OEM Front Indicators
Price: $150.00 (will post at buyers expense or pick up in Melbourne)
Reason for sale: replaced with smoked indicators
Notes:
  1. Includes plastic indicators and bulbs only
  2. Wiring loom and sockets that hold the bulbs in place are NOT included
  3. Tabs are intact
R32 GT-R OEM Front Brakes
Price: $250.00 (will post at buyers expense or pick up in Melbourne)
Notes:
  1. I believe that the rotors are RDA and not the original OEM but not 100% on that
  2. The pads are shot and need to be replaced
  3. I will have the rear brakes available once they have been upgraded to the Alpha Omega Racing EVO Brembo Brake Kit
Please contact via PM for further details.
Cheers
Rob
R32 GT-R OEM Wheels sold pending collection/payment.
A couple more photos and details for the indicators to provide feedback for questions that I have received:
  1. They are in pretty decent condition but that is subjective I guess when compared what you currently have / looking for.
  2. All of the tabs and guides are intact.
  3. The rubber seals are intact
  4. There is a split on the right indicator tab near the screw hole - note that this will not prevent it from being screwed securely into place.
  5. There are a couple of stone chips and a few marks on them
  • 1 month later...
  • 3 weeks later...
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
