Hi all,
Some more parts up for sale.
4 x R32 GT-R OEM Wheels
Price $500.00 (pick up in Melbourne only)
Reason for sale: upgraded to Alpha Omega Racing EVO Brembo Brake Kit so these will no longer fit
Notes:
  1. A few chips and gutter rash as shown in the photos below.
  2. Tyres are not great (you can have them for free!)
  3. Centre-caps are included
Wheel 1:
Wheel 2:
Wheel 3:
Wheel 4:
R32 GTR OEM Front Indicators
Price: $150.00 (will post at buyers expense or pick up in Melbourne)
Reason for sale: replaced with smoked indicators
Notes:
  1. Includes plastic indicators and bulbs only
  2. Wiring loom and sockets that hold the bulbs in place are NOT included
  3. Tabs are intact
R32 GT-R OEM Front Brakes
Price: $250.00 (will post at buyers expense or pick up in Melbourne)
Notes:
  1. I believe that the rotors are RDA and not the original OEM but not 100% on that
  2. The pads are shot and need to be replaced
  3. I will have the rear brakes available once they have been upgraded to the Alpha Omega Racing EVO Brembo Brake Kit
Please contact via PM for further details.
Cheers
Rob
R32 GT-R OEM Wheels sold pending collection/payment.
A couple more photos and details for the indicators to provide feedback for questions that I have received:
  1. They are in pretty decent condition but that is subjective I guess when compared what you currently have / looking for.
  2. All of the tabs and guides are intact.
  3. The rubber seals are intact
  4. There is a split on the right indicator tab near the screw hole - note that this will not prevent it from being screwed securely into place.
  5. There are a couple of stone chips and a few marks on them
  • 1 month later...
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
