hmm link works for me. Results are on their home page rather than their 'Results' page at this stage.
Isn't the other Skyline in your group a GTST? if so, it shouldn't be in SV, its not 4wd... or was there another GTR there on the day?
Yeah the grey R32 was GTSt that guy was telling me all sorts "it can go off the clock, I've had it to 360km's per hour". I was a bit like :P
Pretty sure I was the only GTR there! Aww there webpage isnt working for me...
  • Replies 93
He didn't do too badly considering he was a 2wd in a 4wd class, there is approx 3-4 seconds between my GTR and GTST at the SDMA hillclimb at Fairbairn. According to the results, your GTR did 33.51 and the GTST did 34.42
SDMA would have put the GTST into Type 2 and if there were mods Type 3. I'll have to read the supp regs and try to work out why SV for the GTST.
Congrats michele for ur 2nd and jess for making it in the top 20. BTW michele there is a photo of u and ur march 87b on the back of our newspaper.
Thanks David - I was happy to win my class and stoked with 2nd outright.
Which paper is this one? I'd love a copy if you still have it... what date did it come out?
Yep he did really well, was good off the line too :D They didn't put my third/last run down on results which was a 32.96, I got given the post it note when I finished my run :blink:
Thanks David, Had an awesome time for my first hillclimb and :) for being in top 20!! Will be coming back to the mountain next chance I get!!
  • 3 weeks later...
Are you pumped for the hillclimb??
I wish I was entered, but have a skidpan day on :(
Sat up almost all night last night with my truck packed ready to go... but the rain just wouldn't break :)
So went to the skid pan/back track on Sutton road instead for some training with Dereck at 5th Gear.
Sat up almost all night last night with my truck packed ready to go... but the rain just wouldn't break :ninja:
Awww what a shame :laugh: there is always another one!
Oh it was great weather for skidpaning I was at EC and had a ball got some great in car footage aswell! :P
Awww what a shame :huh: there is always another one!
Yes true, but I would have liked to have a better look at the track before the Australian Hillclimb Championships which is the next event there.
GTSTs are in SV D as they are a low volume import. not sold in australia in full volume. it's ironic that 32 GTRs can run in type 2 etc as they were sold here by nissan, but a GTST or silvia is automatically in SV.
Hmmm I guess different clubs have different regulations - have a look at SDMA (my local club) where they only put the GTRs in SV because of 4wd and they put the GTST in Type 2, which is only fair, my little GTST couldn't compete with the GTRS and if she were heavily modded, she would need to go in type 3.
http://www.sdmahillclimb.com/ then click on highlighted text in the body of the home page "types and classes"
I was running one in each class for a while.
Why don't we get more of you guys down for this?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
