An interesting event has come up via Honda Car Club - on 30/11 - 1/12 there is a hillclimb at Bathurst.
Mount Panorama (The Esses)
4km from Bathurst
run by Bathurst Light Car Club
Record: 22.68 secs - Peter Gumley (SCV) - 13th February 2000
Start is on Mountain Straight and finish at McPhillamy Park.
This is a one-car at a time, timed event up the hill. You can still crash, but it won't be because someone else hit you.....
What you need:
1. CAMS L2S or higher license - you only need to join a club to qualify for this
2. non-flammable long pants, long sleeves, & shoes.
3. helmet
What the car needs:
1. secondary bonnet tie down, eg belt
2. blue triangle located on the bodywork above where the battery lives, eg blue electrical tape
4. fire extinguisher. Should be securely mounted within reach of the driver.
Kelly and I will be going up there for the weekend, anyone else interesting in competing/watching?
https://www.sau.com.au/forums/topic/4617-skylines-racing-at-bathurst/
  • Replies 93
The supplementary Regulations are here on the Bathurst light car club site: http://www.blcc.com.au/November.htm#speedweek
Richard Colley at HCC is our contact 0410 664 140, I'm going to try and sign up myself in the next few days.
Do you have a fire extinguisher or any suggestion on who to speak to to get hold of one?
oh god yes! how much fun would it be having a fang around bathurst!!
but due to having a stockers car, crap tyres, brake pads that are due to be replaced, no helmet, no fire extinguisher, and no CAMS L2S licence...I'll have to say no :D
oh, and i've never raced my car anywhere before and would look like a slow-arsed idiot :mad: there's another reason :P
According to the regs, there's no closing date for entries.
And Shell, the only hard bit is the extinguisher - Kelly and I are both doing our first hillclimb here. (and our car's stock too). None of the skylines will be the fastest, hillclimbs are pretty open in classes, and some crazy open wheeler ex-f1 car will be a long way ahead of us.
Just going to have fun, and the chance to race at Oz's best track.
For those who don't mind going fast, there's also a timed sprint down conrod straight on the Saturday. Hope the speed limiter is gone:crazy:
Any estimates for speed before braking for the chase?
  • 3 weeks later...
Originally posted by Duncan
*Bump*
C'mon all, we need more than 2 skylines to take on the crowd at Bathurst.  Anyone else interested?
I am very interested Duncan, however my employer is also interested in me being at work then. :D
Maybe next time...:uh-huh:
I already have my license, but Kelly is hunting one down now, I think she's going to join Honda Car Club - I have their details if you like.
I think entries are closing this week, so you'll need to be quick!
Fatz, Kel and myself are going so far.
Well, despite a few skyline drop outs (looks darkly at Kelly and Pete), it was a great weekend at the mountain.
I came second in my class (lightly modified over 3L) behind a big hp senator in both the hillclimb and the sprint. Apparently that bloke could steer a bit too, he's an ex-group A racer so its not as embarasing as it could be to be beaten by a commodore. :Oops:
Pics and videos are here:
http://www.hgeconsulting.com.au/bathurst.htm
And there's always next year:D
Red, they're at the top of the page, just wave your mouse over them. Not too exciting though.
Silver-Arrowz, its at least an annual event, so I'll try and rustle up a bigger crowd next time. Top fun!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
