Hey SAU first post here :)
Just want some advice as dont know a huge amount about skylines. I just went for a drive in my r33 gtst and just had a quick loss of power almost like a complete cutout of the motor for a second. Im running standard boost and car is completly original besides a K&N pod filter. Currently it is extremely hot here in SA probably around 44degress outside so not sure if it has anything to do with it cause it was doing it at higher revs when i put my foot for a second. A friend told me about heat soak or something on hotter days. Could it be doing R&R or was risking detonation cause of the hot day so ecu was protecting the motor lol. Any advice would be greatly appreciated. The car only did it once just then and hasnt done it since.
Thanks SAU
https://www.sau.com.au/forums/topic/461703-r33-gtst-cut-out-at-high-revs/
I had to drive on Hume Highway in 2012 on the day of the big bushfires..........48'C. I couldn't go over about 85km/h. Oil and exhaust temps would just soar into the danger zone if I did. Actually had a Highway Patrol car follow me for 30km waiting for me to do something wrong and just as I came into Holbrook - and it was two way traffic - a 4wd going north caught his interest so it was lights on and a quick U turn and he was gone. My aircon actually stopped working it got that hot!!!
So I'm with Kinks, poor Skyline being boosted on a 44'C day!!! Remember your Skyline is an old car 10-20 years old in fact. Have a look around you and see what other 15 year old cars look like - most are ready for the tip!!!
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
