On 8/5/2016 at 7:20 PM, conan7772 said:
ok sorry revisiting this again.
People are constantly commenting how loud my car is so back to work on it.
My exhaust is Legalis R, twin 83mm tips. Fujitsubo stamp on the rear muffler
Rear muffler is straight through with a perforated inner skin. (Boomer)
I can see the inlet with a torch.
Internal outlets look 50mm then flare to 83mm
Can anyone confirm this is the genuine design for this system ?
Thinking of fitting a chambered rear if it won't be too restrictive..
thanks
Sounds about right, but what about the rest of the system?
  • 3 weeks later...
Yep it looks like the Legalis but who knows what the mid muffler is.
Anyway fitted two silencers into it.
Way more quiet, went from 105.4 Db to 95.7 Db at 4000 rpm
Sounds a bit deeper, and all that crackle has gone.
Shouldn't effect my power levels either.
The exit orrifices in the muffler are around 46 mm then flare to 83.
These cheap silencers have 39mm pipe, which I cut a bit shorter so the ends were well in the 83mm section.
Had to dremel the shit out of the tips to get them in.
MOV02764.AVI
MOV02766.AVI
  • 4 months later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
