FOR SALE LIST
Please text 0431143031 with any questions or for further photos
CUSCO 6 point bolt in roll car suit non sunroof S13, only owner in great condition
$750
Microtech LT12S Suit RB
Comes with S1 RB25 engine loom and hand controller
$600
RB PULL TYPE CLUTCH
EXCEDY Heavy Duty pressure plate
5PUK NPC Sprung center clutch used for a handful of track days
$400
Genuine 53mm R32 RB KOYO Radiator, great condition comes with r32 GTR fan shroud
used for a handful of track daysv
$350
Genuine 37mm 28 Row PWR Oil cooler
Comes with lines and sandwich plate
$250
GReddy Style copy intercooler
W 66mm H 300mm L 640mm at top 780mm from inlet to outlet
$200
Surge tank set up
With 2 year old genuine bosch 044 fuel pump (working when removed from car)
$150
Set of 440cc RB26 top feed injectors (Rail not included)
$150
Genuine Tomei fuel pressure regulator
Comes with gauge (no lines)
Used for a handful of track days
$80
Catch Can with lines and filter
$50
MONZA 4 Point Harness
$40
Speed Meter mechanical oil pressure gauge
$20
SAAS Water Temp Gauge
Comes with gauge, neck, sender and hose from an RB25 top rad hose
$40
Edited by aaronfalafel
https://www.sau.com.au/forums/topic/462118-s13rbr32random-parts/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
