I have my Vipec V88 ECU for sale.
Included is a complete adaptor loom, so you can remove the factory ECU, plug in the adaptor loom and then the Vipec V88. All done professionally, it does look good, will post photos later.
Other bits are a 7bar MAP sensor and the cable to go from the ECU to USB port.
Price $2200.00, can ship at buyers expense, located in Adelaide SA.
Prefer text or call 0456969001
Mike
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
