I hope you guys aren't using those cheap knockoff MAP sensors off Ebay.
The Greddy MAP sensor is the most important part of the Emanage tune, and knockoff sensors seem to be the cause of an engine failure or two.
  • Like 1
Seconded. My cheap sensor is junk up top. Very noisy on boost. Varies 4-5psi. I feel this has a lot to do with the plenum pulses. A HPX-N1 MAF would be my preferred option. Since resolution would be more than enough and plenum pulses wouldn't be a factor. Map filtering works but gives lazy response (worse than MAF response due to the inlet track)
Edited by BoostdR
  • 4 months later...
Hi All,
As promised here is a copy of my install notes. Water temp is external as I found the OEM sensor signal to skew when tapped.
Innovate LC-2 wide band is used for narrow band emulation and EMU autotune
Vehicle setup: VQ25DE OR VQ35DE
Speed pulse: TBA(think it was 16pulse, 21% correction)
If someone has spare time and wants to put this info in a neat spreadsheet please go ahead.
Matt
EMU Earth isn't to pin 106 it should be pin 47
  • 6 months later...
  • 3 years later...
Hey guys, tried my Emanage install and seem to have blown up the unit. No power after running for a while, got a red light then died
anyone got a spare unit? Or know if repairers in Sydney?
Found one - Let install pt.2 begin..
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
