Hi everyone.
I'm parting out my R33 GTST.
Heaps of parts available...
Dash 100
Centre console 80
Shifter surround 30
Dash surround 80
Glove box 25
Window motors 80 each
Climate control 60
Front door trims 40 each
Rear trims 30 each
Seat belts complete 150
Cluster 180k 80
Drivers window switches 70
Passenger switch 20
Rear seat 100
Low mount seat brackets 100 pair
Skyline door runners 50 pair
Pedals 70 set
Interior light 15
Map light 15
Skyline front mats 50
Parcel shelf 30
Pillar trims 20 each
Rear window trim 20 each
Door glass 50 each
Rear view mirrors 40 each
Rear skyline garnish 50
Steering rack 150
Brake master cylinder 100
20k km Executive heavy duty clutch 100
Alternator 70
Ac condenser 50
Heater core 50
Front castor rods 50 each
Control arms 50 each
Ac pump 100
Power steering pump 100
Stock intercooler 50
Cross member 100
Rear reo bar 50
De cat pipe 40
Bonnet latch 30
Fuel tank 40
Washer bottle 20
Wipers 20
Radiator overflow 20
And more...
Let me know what you need.
Parts located in Glen Waverley 3150.
The following items are already sold -
Gearbox, turbo, injectors, coil packs, ECU, AFM, FMIC, fuel pump, headlights, radiator and shroud, grill, brakes, suspension, tail shafts, air box, spoiler, front reo bar and car shell...
I'm chasing the clutch pedal assembly with clutch master cylinder, Brake pedal and complete hand brake assembly if they are available.
Happy for you to PM me a price with postage to 3858, Victoria.
Cheers
Edited by DRF72
Pm's sent.. Better late than never..
Most of it is still for sale and price is negotiable.
Minus heater core, d window motor, p window glass, dash surround, pedals, clutch master cylinder.
Let me know what you need..
Cheers.
Straight up guy, A++ seller.
Posted all parts requested with in 1 day of receiving funds, with tracking and exactly as described.
Very honest and reliable.
Thanks again mate.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
