  On 03/02/2016 at 12:10 PM, silvia_15 said:
"All imported vehicles with a magenta (purple) compliance plate whether from the ACT or another jurisdiction must be inspected at the Dickson Motor Vehicle Registry."
That is from the website. I think all Skylines and Silvia's have a purple plate - so no matter where you buy it, to transfer rego to your name in the ACT you would have to go to Dickson. I think we all agree here.
So the consensus is:
FMIC should be fine, even with hole cut through battery tray.
Pod should also be fine if held properly.
Boost controller will need to be hidden.
Any issues with the MCA coilovers? They aren't too low or something?
And one other point: I was thinking of having the car checked by some mechanic that can report to me. I inquired with Stateroads and they charge 290 for a report - its 6 pages and basically is a tick for satisfactory or not satisfactory for a list of things. Mainly it will point out a more major fault. Is it worth going with them or is there a better/cheaper alternative? I would like a check for the peace of mind.
I had paid for stateroads to do an inspection for me. Well worth the penny. It's a full report from paint correction to to rust to mechanical issues. I would use thees guys whenever I buy a car over $10,000+. Ease of mind and you know what you're paying for instead of calling their mechanic for a bias opinion. GL.\
I still have the report for my car - If you'd like to check it out. Give me a PM with your e-mail address and I'll send it over.
Edited by RosieR34
Have you considered asking the seller to drive the car to the Dickson pits for an inspection to see if it will pass before purchasing? I know it will be a hassle but for Sydney sellers might be worthwhile giving it a go so that you purchase knowing for sure. Might be an idea to look into an adm s15 instead as pretty much most things will be parted out that was different probably with the exception of rear window wiper and the digital climate control unit. Just a thought to save you more hassle than required.
Yeah I might ask him if he has plans to come down. Probably won't happen though.
If the car is mechanically good and history is clean then I would be willing to cop a bit of hassle. But really I am wondering why Dickson would make life so hard? It's not heavily modded.
Is hiding the boost controller really hard? And if the FMIC fails then I have to go stock? All else shouldn't be an issue I feel.
And I know the pains of not going back within their 28 days (or whatever the fk it's been reduced to now, allegedly) and having them discover things they glazed over the first time - blindingly obvious and ridiculously irrelevant things - resulting in another failure even though I fixed the issues from the first one. Kents.
Wondering what people's thoughts are on amount of boost. Stock S15 turbo (T28 ball bearing I think) running around 12-15 psi of boost. Would you get concerned about the longevity of the turbo - or is it pretty reliable? What sort of numbers do you all run (on Skylines)?
Also has anyone got a power brace fitted?
S15 stock turbos will happily run 16-17 psi but can't hold that till redline. They usually drop to around 14-15 psi in the top end. This is when your ecu is tuned otherwise 12 psi max.
In skylines most guys with aftermarket turbos run 18-20 psi. Some push them a bit more.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
