unfortunately my car got written off so the carbon fibre parts i've hoarded and intended to fit are of no use to me now and up for sale they go. :(
1) R33 GTR short length radiator cooling panel (carbon Fibre) - $150
2) R33 GTR/GTST exhaust shroud (carbon fibre) - $90
3) R33 GTR/GTST fuse box replacement cover (carbon fibre) - $110
4) R33 GTR/GTST S1 NISMO 400R style bonnet lip (carbon fibre) - $150
can do abit cheaper if buying multiple items.
pick up in liverpool/gladesville
can ship interstate at your expense.
cooling panel - $15
to ACT/NSW/QLD/VIC/TAS/SA
WA/NT add $5
bonnet lip, exhaust shroud & fuse box cover Aus wide - $10
all with tracking and insurance
all items are new, carbon fibre finished in glossy clear coat.
https://www.sau.com.au/forums/topic/462813-r33-gtrgtst-carbon-fibre-parts/
  • 1 month later...
Bump
only have 1) R33 GTR short length radiator cooling panel (carbon Fibre) - $150
$140 + $15 post if needed.
found a spare R33 GTR Nismo 400R style bonnet lip in white fibreglass, $90 + $8 post if needed.
  • Like 1
  • 4 weeks later...
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
