not sure if correct place to post, Sorry admin.!
So just to settle the argument that i know some one will start....yes 20E in a 4x4.....because we can. and there cheep!!
Hey all, run into a small issue with my 20E conersion.
Did not think it would be very hard but have no idea were to start tbh.
I have got the motor all mounted.
bolted up to the 4x4 gearbox.
Starter on, alternator on.
running off the factory D21 petrol loom.
The issue i have is no idea were to start at all with wiring up the 20E Ecu.
Hoping some one could give me a take wire from here to this pinout number.
have got motor cranking over easily and getting fuel.
I am not worried about the dash tacho at all. nor the engine light or oil light.
This is all going to be run off external pod guages.
so just need to get her running, cheers in advance and much appreciated.
have attatched 20E loom diagram, pinout and truck photos for those interested!
20E pinout
20E engine diagram
20E mounted Snug As A Bug
Thanks in advance!
https://www.sau.com.au/forums/topic/463163-rb20e-d21-navara-convesion/
Small update :
Have got spark perfectly.
Have fuel round the right way and fuel pressure to the injectors.
Injectors tested and are working.
Except. When cranking the motor no fuel is flowing into the motor.
Now if i go acc on the key, and turn the dizzy ( inside factory adjustments) i can hear i assume only one injector clicking.
Has any one ever seen this issue?
Thanks in advance.
  • 3 years later...
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
