  • Replies 42
The rb20/26 inlet cam gears bolt on the same a the exhaust ones (4 bolts) but the rb25 has one large hollow banjo style bolt that holds the vct gear on.
So without modding the center of the cam aswell as the front bearing surface the stock vct gear wont fit so you need the rb20/26 pully.
John
surely if you put gtr cams onto hydrolic buckets your seat to seat timing would be increased to the point that idle quality will suffer, unless you plan on letting the buckets pump up and running a lash setting that match the gtr cams,  18 thou or something like that.
Not actually correct as the hydraulic follower allows clearance, due to the timing of the oil inlet, but let's just say it doesn't....
Then you end up with 18/1000 extra lift, this is not a bad thing :rofl:
And you end up with longer duration, again this is not a bad thing :D
I really can't see a problem, an RB is not a an old style engine with the hydraulic lifter at the opposite end of a push rod. :D
Just interested in discussing a recent incident with an RB20 that fitted GTR cams. The owner believes some of the inlet valves were staying open off lobe. So would the problem be:
1. The hydraulic follower is pumping too far open
2. the extra lift is pushing the follower too far into the guide and making it stick(the engine is 180K old), I think unlikely. it would stay well open.
3. the off lobe diameter of the cam is a larger diameter than the stocker and the hydraulic follower is jammed at one clearance and won't close to accomodate.
4. bent valves due to timing belt slipping a few teeth as the inlet cam was apperently very tight in the journal.
There were signs of at least one set of valves touched the piston so the timing would have been out slightly, but at least 3 sets stay slightly open. I'm yet to see the head but very keen to follow up and see if they ar all bent valves or one of the other problem I mentioned.
  • 3 weeks later...
  • 3 months later...
We are doing this conversion but modifying the inlet cam to run the VVT. May be crap but costing nothing to find out so will let you know.
This is on GTSt VSPECs GTS that has 450rwhp on the Stock cams so should be an interesting test.
Has these been done yet??
Any results available?
I have 3 sets of GTR cams and would like to put 1 set in my RB25det if it is worth while.
Save your energy guys, this swap does NOT work.......GTR cams are designed with ramps suitable for .015"-.018" clearance with solid lifters. Put them in a hydraulic lifter engine (RB20-25) with .000" clearance, and you now have longer duration, but ultra-low lift for a fair portion of that duration! Result = bad idle vacumn, crap power, etc, etc.
With that said, I do have 2 sets of GTR cams for sale...$200 per pair, so if you still want to try this swap, knock yourself out. :kick:
B.
Which is why it works for Sydneykid, and the suggestion that it wouldn't work due to ramp angles was laughed at by one of the Northsides' (Melb) better engine machining and building shops.
So you will of course provide dyno charts to support this advice? Make it quick as I'll be limited to occasional whoring from Thailand from 12 tomorrow.
I'm more than happy to concede to concrete evidence that it won't work, but there is evidence to the contrary.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
