Hello everyone.
Spool RB30 H beam rods complete set 7/16 bolts
Rated 1000hp $450
Rb2530 20thou CP flat top pistons x5 $400
Rb20 Metal Jacket 1500hp balancer $400
Arp rb25 head studswith all washers and bolts $150
Rb20 alternator $50
Rb starter motor $50
Braided, Teflon and heat covered turbo oil and water lines $150
R32 front brake callipers with pads, new front and rear $100
R33 GTR slotted brake rotors, not used, can get machined Rda brand, $100 for the pair
R32/33 boss kit and wheel, just needs screws and horn piece $50
Rb25de head with intake, needs machine from washer hitting quench area, fixable, talk to Mick at Probuilt, come with exhaust manifold and head studs (arp), has 110lb upgraded springs $500.
R32 ac compreasor $30
Brand new TOMEI Rb cam gears In and Ex $275
Light use Triple plate Xtreme carbon clutch, suit 26 spline Holinger or OS88 sequential gear boxes $2300
Light use NPC 10 Inch heavy duty clutch and flywheel $500
Have NO idea how to attach pics via Iphone. Can mms to you no worries.
This is everything left.
If there is ANYTHING you see here, and the price is a little high for you, PM me and I can negotiate something else within reason.
Thank you.
  • 1 month later...
Still for sale
Rb2530 20thou CP flat top pistons x5 $500
Rb20 1500 hp Balancer $400 (will suit rb25/30 conversion into r32 gtst aswell)
Denso Low impedance 650cc injectors, resistor pack, rail, fpr, as kit $350
R32 Gts4 Sump with Diff $200 as had a crack welded in sum base, no leaks.
R32 Gts4 4.33 Diff, same CV's as R32 GTR and can supply centre hubs to suit $450
R32 Gtr tail shaft, $100
R33 gtst front rebuilt callipers, new pads, and near new rotors $300
Full set of R32 GTR Bilstein Shocks in VERY good condition $650
Will also have Apexi Power FC D-Jetro and hand controller for sale soon with a micks motorsport tune on it for an r32 rb26, 1000cc injectors, 393rwhp, have dyno sheet, looking for $550.
Willing to negotiate on priceS
Still for sale
Rb2530 20thou CP flat top pistons x5 $375
Rb20 1500 hp Balancer $350 (will suit rb25/30 conversion into r32 gtst aswell)
Denso Low impedance 650cc injectors, resistor pack, rail, fpr, as kit $300
R32 Gts4 4.33 Diff, same with CV's ( same as R32 GTR) and can supply centre hubs to suit $400
R33 gtst front rebuilt callipers, new pads, and near new rotors $300 (can also supply rear, with rotors and near new pads, total kit cost $375)
Full set of R32 GTR Bilstein Shocks in VERY good condition $550
Delphi 1000cc Injectors with Resistor pack (I have 2 packs) $350
  • 6 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
