Update, just got home from fishing trip and have now received moniez from Eric,Elle,Colin,Dean and Dan.
Your stickers were posted today before close so hopefully you all have them for the weekend :)
Delivered couple sets off to Corey today too. Am going camping for the rest of the week so any orders will be sent Monday onwards.
  • Like 2
On the camping trip if you happen to see jason say hi from me [emoji6] but really must say am a little jelly been ages since I last went camping
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
