Is anyone playing Clash of Clans???
I started on it and now I'm hooked, was playing computer games [still do a bit] but CoC is taking over my life!!!
And you can never rest - its like a baby, you have to keep going once you start, there is no getting off.
https://www.sau.com.au/forums/topic/464037-clash-of-clans/
lol, did say I was addicted, already maxed at th9 and going to th10 as we speak. And yeah upgrades are a bxtch!!! 12 days from th9 to 10. Walls 3 million a brick and takes a couple of days to get that, so times that out with 250 bricks and you ahve another Xmas drifting past. Been playing for around 2 years now, just surprised there is no thread on here for it was all?
I did search on CoC and Clash of Clans and found nothing.......so assume this is the only thread [till i'm told otherwise].
https://www.sau.com.au/forums/topic/464037-clash-of-clans/#findComment-7707117
TH10 here, can confirm the grind is real.
Although If you like CoC, have you tried their recently released Clash Royale?
Myself and a lot of my CoC Clan have made the migration and only really check CoC now to collect res.
https://www.sau.com.au/forums/topic/464037-clash-of-clans/#findComment-7707130
No not yet, had some in my clan try it, but with mixed feedback, some think its shallow and lacks the strategy depth that CoC has. might try it later, but not rushing to it for now.
I also want to state that my base is built, not bought!! I don't buy gems and anything, its all raiding and wars that pay for it.
https://www.sau.com.au/forums/topic/464037-clash-of-clans/#findComment-7707483
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
