Hi yoshiFD3S, you should also mention that the hand controller is the newer el version with the yellow wringing as the older model is not as good. So what way you going? Cheers.
Thanks, Mick! I forgot about that.
I just found out I probably won't be staying in Oz for more than about another year so I've decided to tone down just how much I even invest into the car since I'll just have to sell it. :(
  • 4 weeks later...
