Reducing my stock of dampers and springs. All of these setups have been valved/sprung for the 'real world' (using a proper shock dyno). Handling and ride are well balanced ie you won't bounce off mid corner bumps or skip across the tarmac when you stand on the brakes on an uneven patch of road. All sets have done less than 2000 km road work. Prices plus Auspost or pickup in Canberra (can meet halfway between Canberra and Sydney by arrangement).
Details:
Konis. Adjustable valving and ride height (spring seat grooves cut into shock body). Revalved by Toperformance Melb to provide a more compliant base setting (stock Koni valving is suited to Japanese roads and ridiculously hard). Note they do not come with spring hats shown. $475
Bilstein SK. Adjustable ride height. Includes coilover adapters for use with standard spring hats. Red springs are Eibach. $650
Bilstein PSS9. These are a serious damper. Adjustable valving and ride height. Blue springs are Bilstein, red springs are Eibach. RRP around $2k. $900
Brembo F40 calipers with adapter brackets. Not sure what size discs the adapters suit so selling these as a pattern only (if you need to get adapters made up it should be cheaper). Very good condition barring one slightly torn seal due to it being jagged by a slipping screwdriver when working on something nearby :angry:. $500
Happy to answer any questions, no low ballers please.
  • Like 1
All dampers back up for sale due to time wasters. Potential future time wasters please note:
The FS forum and those who post in it aren't here for entertainment purposes to ease the boredom of your day.
If you just want to ask questions and find out about suspension tuning do it in the relevant tech forum so others can learn and contribute.
Don't ask for a postage calc to your location, and then say you don't have funds. Or ask lots of detailed questions about spring rates/ride height/setup, get excited and say you'll take them, send your postal address, and then reneg.
It's free to send PMs but if you're a time waster it will probably come at a cost to your reputation.
And genuine buyers with funds please feel free to PM :cheers:
Edited by Scooby
  • 5 weeks later...
  • 1 month later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
