Outcast Posted May 8, 2016 Share Posted May 8, 2016 hey guys new here my name is joshua.I'm from adelaide I own a gts4 r33 coupe that i am turboing atm. im just wondering what kinda spe*cs the turbo in the title would make>? thanks for the help guys. P.S hope to get to know you all josh Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/ Share on other sites More sharing options...
Ben C34 Posted May 8, 2016 Share Posted May 8, 2016 A shit one Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7723997 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 (edited) Hi ben whats so bad about it?Been told it would spool max 3500rpm psi at 20 max i think .What i was told just some is sell it thats all just a question what does a high flow spool at? Edited May 8, 2016 by Outcast Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724000 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 The mods they is will all ready has. Front Mount return Flow so no cutting up the car Nistune Hks Type S gtr oil cooler hks front pipe hks TI Exhaust 650cc injectors HKS Reloaded racing pod filter set up more to come when i remember josh Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724005 Share on other sites More sharing options...
Ben C34 Posted May 8, 2016 Share Posted May 8, 2016 The turbo, aside from not fitting into a gt30 housing, is too small. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724006 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 (edited) mmmk i get what you are saying been told 230rwkw is what it would make was making the car to spoll fast i.e kinda wana do some trmac rally one days lmao. ah so would it spol faster then a high flow? Would it be possible to use a diff rear housing then .64? Edited May 8, 2016 by Outcast Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724007 Share on other sites More sharing options...
admS15 Posted May 8, 2016 Share Posted May 8, 2016 As said it is too small. It would probably make 210rwkw max if your lucky. A hg high flow will make an easy 250rwkw on 98 fuel with full boost around 3400-3500 rpm. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724010 Share on other sites More sharing options...
admS15 Posted May 8, 2016 Share Posted May 8, 2016 You may as well leave stock turbo instead of that. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724011 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 (edited) yea get what you are saying the gt2510 has been mach ined out to take the gt3071 so should be making more power then 210 with them mods no? P.S the turbo has been highflowed to fit the gt3071 so should make more hp right?/ Edited May 8, 2016 by Outcast Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724013 Share on other sites More sharing options...
admS15 Posted May 8, 2016 Share Posted May 8, 2016 So theres nothing 2510 about it. Its a 3071 machined into a 2510 front cover. How many $ is said turbo. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724016 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 ahh yea new to turbos and stuff what is a gt3071 like? how much could this kinda turbo make. and i should be able to get it pretty cheap Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724017 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 yea its been highflowed to fit the 3071 what would it be like seen the houing on the back is smaller but bigger turbine? should sspool queick? Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724019 Share on other sites More sharing options...
Ben C34 Posted May 8, 2016 Share Posted May 8, 2016 Don't buy it. Buy a Hypergear high-flow Direct bolt on Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724024 Share on other sites More sharing options...
Ben C34 Posted May 8, 2016 Share Posted May 8, 2016 How much is the gumby turbo you are looking at? Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724025 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 200ono nearly new Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724030 Share on other sites More sharing options...
admS15 Posted May 8, 2016 Share Posted May 8, 2016 Its sounds like a bastardized mongrel turbo. You could buy it waste a few hours putting it on and tuning $ and then let us all know if it works out. I'm with Ben, hg highflow bolt on. Its proven and u know what your getting. But up to you. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724035 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 true true just seem like a good price an all i mean how many kw you think it would make highflowed? and a question is a high flowed stock turbo ball bearing? Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724038 Share on other sites More sharing options...
iruvyouskyrine Posted May 8, 2016 Share Posted May 8, 2016 Just drop the idea of using that bits and pieces turbo. It will be shit and give you lots of problems. Just buy a standard blown up R33 turbo and get it high flowed. It's a bolt on affair and will be oh so easy compared to this frankenturbo. Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724073 Share on other sites More sharing options...
hypergear Posted May 8, 2016 Share Posted May 8, 2016 need very big turbine side for na engines to work Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724096 Share on other sites More sharing options...
Outcast Posted May 8, 2016 Author Share Posted May 8, 2016 ah i thought your would't need a very big turbo as its NA and yea running comp andthought the high flow hks would work well low spool time,can only run 200 ALL wheel Kw anyways? Link to comment https://www.sau.com.au/forums/topic/464683-hks-2510-with-gt3071-64-housing/#findComment-7724113 Share on other sites More sharing options...
