Good day everyone, I'm new to this sight and I'm not even sure if I'm doing this right or posting this in the right section or not. I have a skyline r34, it has the rb25det neo motor, I have an issue that nobody can seem to solve, please can someone advise or give help. I'm from south africa and we don't get the skyline this side so I had to import mine, so not many guys have experience in fixing this car. Firstly the car was stock.when I came to upon this issue the car would loose power like it dropped a valve but it would happen.every now and again, I had it checked out I was told my spark plugs were wrong so I did research on sights got the right plugs and even gapped it to 0.8mm the car ran fine for awhile then the same issue returned about a month later, I then replaces the coils, once again it worked for a month then the problem returned, some said my ground of the car was not right. I sorted that out but the problem was still there, I then changed my injectors found out one was faulty. The car worked fine for about 3 months then the issue came back and shortly after that the piston melted and the xonrod shot through the block I replaces the motor and put a spitronics management system in now my engine light doesn't want to go offend the new motor is giving the same problem. I don't know how to.fix this issue. Please some advice would be great.
https://www.sau.com.au/forums/topic/464702-need-help/
  • 4 months later...
First off stay out of boost until you have a handle on what is going on with the car.
Two start eliminating problems.
Check fuel pump and fuel pressure.
Use multimeter to check earth's
Your check engine light is triggered by the ecu.
Trace the wireing to your ecu and double check every single pin on the ecu harness vs the plug on the engine.
Read the ecu manual to see if it's doing something daft.
Get your car on a load bearing dyno and post a dyno graph.
With Afr and boost.
https://www.sau.com.au/forums/topic/464702-need-help/#findComment-7775537
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
