https://www.google.com.au/url?sa=t&source=web&rct=j&url=http://nistune.com/docs/Z32_ECU_Modifications_Direct_R33_Plugin%2520V8.pdf&ved=0ahUKEwjYrK7y8MvMAhVFHaYKHRyVD2MQFggaMAA&usg=AFQjCNHPYhrNsFbbIq-BjtzZjbgbCap3Mw&sig2=3Ng6DuTFNwbkVE-GeIupyw
That should link to a pdf from nistunes website. Read that and ask if you have any more questions. If the link doesn't work Google nistune z32 r33 and it will be the first link at the top of the page
https://www.sau.com.au/forums/topic/464706-rb25det-nistune/#findComment-7724479
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
