Gday,
In the near future i am going to have to get oil and water lines and fittings for my new setup and i have a few questions.
I dont have any of the copper water feed/returns on my engine and i dont have any of the oil feed/return lines either.
I'd like to know:
1) what sort of fittings i will need..
2) aproximate length of hoses required...
3) type of hoses required... and
4) prices i should expect to pay
I am also unsure where i get the water feed and return from. I take it the oil feed and return are all on the exhaust side of the motor. But i am using a greddy plenum and will be redoing all the hoses on the intake side so i dont know if i should run a water hose from say the water heater circuit, or can i tap into the block somewhere on the exhaust side to pull water from?
any help would be appreciated
Dave :headspin:
https://www.sau.com.au/forums/topic/46475-oil-water-fittings-gt35-turbo/
Thanks for the info Bl4cK32
i actually was looking at horsepowerinabox this morning and that was sort of motivation to ask this question. I noticed they sell a complete kit but for $247. So i was wondering if thats an average price to pay, or if it can be done cheaper.
I also want to guage pricing so i can get quotes from enzed and pirtek.
all your water and oil lines for the turbo will be on the exhaust side.
when i upgraded turbo i had to get one of the "GT fitting kits" from GCG. these kits include all the fittings from the turbo for GT type turbos (HKS GT and garrett GT series) once i had all the turbo fittings it was a matter of making a trip to your local fittings shop like Enzed or Quickfix. where i got all my lines and matching fittings for the block side.
I used stainless braided line with teflon inner. make sure you get the teflon stuff cause it doesnt perish under extreme heat. as for the oil return (the chuckiest return pipe, I bought some silicon pipe from GCG to match and just used some quality hose clamps.
good luck!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
