Will need to replace centre caps but other wise
19 x 8 +35 offset should fit according to the large amount of forum scrolling I did. I will probably fit 245/45/19
Are those really Audi wheels? If so I believe they are 5 x 112 (nissan 5 X 114.3) and the centre bores are only 57.1mm (Nissan 66.1mm)!!~
Old cabin air filter is yucky, new one is clean and white.
But the space where the ioniser is supposed to be is empty. There is a light on the dash by the drivers door, but not even a plug by the cabin fan to say it was ever there. Did they relocate it in the series PM35?
  • 2 months later...
