Event:
Happy Laps - Lakeside Park
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Breakfast will be served with bacon, eggs, beans and toast.
Lakeside Park
Date:
Saturday the 25th of June.
Time:
7:00 AM Arrival
7:30 AM Breakfast
8:00 AM On Track
Cost:
$35 for members
$50 for non members
Please note that this is a per person cost, any passengers are required to pay as well.
If you wish to come along to watch and not have breakfast it is free.
Requirements:
1. Participants must meet minimum age requirements for being on track.
2. The overtaking car is responsible for completing the overtaking move safely.
3. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
4. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
5. Cars should not be more than 2 abreast at any point on the track.
6. Be aware of cars around you, in front and behind (and beside when being overtaken).
7. Do not assume that the car in front of you knows you are there.
8. Please pay cash on the day, no EFTPOS is available.
Lakeside Specific Rules:
9. No overtaking or cars side by side on the kink.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
https://www.sau.com.au/forums/topic/464963-happy-laps-lakeside-park-25062016/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
