It's been AGES since I've last come onto these forums, but I figured this would be the place if any to put this up...
Clearing out my storage boxes, I found my brand new blank Nismo Design Key that I bought from the Nismo Omori Factory in Japan about 10 years ago.
It's completely un-touched, and ready for cutting.
Those who have been looking for one will know how hard these are to find, even more so in a blank, un-cut state.
I have no idea what it's worth today, but using a similar listing on eBay (where they are asking for $680), I'll put mine up here for $500 neg.
In no rush whatsoever to get rid of it, so don't waste your time with low-ball offers... It's been a while since I've visited SAU, but if you look at my post & thread history, you'll see I was a very active member (NSW Exec at one stage).
PM / Email ([email protected])
Hey mate, tried to send a PM but looks like your inbox is full.
I'm interested in this, PM me if you could. Cheers
Sorry about that, didn't even check... inbox should have space now.
  • 2 months later...
  • 1 year later...
21 minutes ago, dan the man said:
Still got it? Cash waiting
Yep... Just dusted it off the other day, these should be as rare as world peace these days, will need to see how many (if any) are still for sale and for what price.
18 minutes ago, niZmO_Man said:
At least $1,000 USD
Thanks.
Due to a recent resurgence in interest, I've taken another look at what's available on the market... there's a grand total of 1 going on ebay for 640GBP which is well over $1k, another forum post suggests 120,000 JPY is not uncommon on Yahoo JP if and when these come up.
I can't seem to update my original post but the price is now $800... expensive for a blank key yes, cheap for a true collectors item and one of the few things that will continue to go up in value if left un-touched.  As such, in absolutely no rush to sell :)
  • 11 months later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
