Im wondering if any of you guys using standard nissan valves on a rb26 with BC valve guides. I notice that the exhaust valves fit the exhaust guides but the intake valves are tight on the intake guides and wont fit. Also both intake and exhaust guides are different lengths. The BC guides are way longer than the factory guides.
Im wondering if any of you guys have this problem. I can only imagine once the guides are fitted into the head that it will get even tighter. I have post a photo to give a better idea. I cant get around the thought of the intake valves not fitting the intake guides. Like in the photo. Like the exhaust valves. In the photo its std size but supertech valves, but i have tried the factory vavles as well, and the same intake valves dont fit the bc guides.
https://www.sau.com.au/forums/topic/465760-bc-valve-guides-valve-wont-fit/
It is normal to have to ream new guides to suit the valves that will be running in them.  It is also normal for aftermarket guides to need to be shortened, especially as they often get installed in heads that are getting ported and would need to be shortened even if they were supplied at the factory length.
^^^ 100% correct.
I had a machine shop install them and ream them to specs. But you are definitely doing the right thing by dumping the stock ones! 2 of mine were chipped off when I tore my engine down!
Good luck. It's not cheap, but worth the upgrade.
Thanks mate. Seems like im down the path of stacking up on some good tools. Well as for the valve not fitting. I just figured out ill need to hone them. My choice is a flex hone. Also will need a ball gauge to find the inner diameter of the end hone.
Question. Does anyone know of the clearance im looking for when i hone it. For both intake and exhaust?
I really want to try this myself. I have removed all the guides perfectly, i gut the head up to temperature and pressed them out wit no scaring of the aluminum i couldn't be happer.
One thing im confused about though is the length of the guides. Is this normal and where do i put the long side. Or space it out equally.
Opps didnt see this. How have you been mate nice to hear from you. Thanks as usual
^^^ 100% correct.
Thanks sir. Intrested in what shop you used. Seeing that we are both from state side.
Sent my head to RAW Brokerage...right there near you. They have a machinist. Make sure you get ALL of the things you want done to your head in writing first. They did good work, but we did have a miscommunication on what I wanted them to do overall. It did take quite a bit of time as well.
Hi Marcus, I'm good enough.  Don't try to hone the guides.  The correct technique is reaming.  Do your usual youtube research - there's bound to be someone demonstrating valve guide replacement tasks.
I was thinking of using them. My next choice was port flow design in CA. RAW Brokerage i like because i can travel there personally. This is my, i guess you can say experimental head. My try. For notes the valve to guide clearance is 0.1m (0.004)
Tomorrow ill try to trim the guides to the right length heat the head up again, and using some nitrogen dip the guides and quickly install them. I spent 2 days making a guide jig so that i cant over press it to deep. Once there cut to the right length i.e stock length i hope it goes well. Ill have to wait for my ball gauge to arrive along with my flex hone.
As for now im looking for a reamer tool, and if i get this right the honing comes after i ream it. Choosing the right size reamer is the next hard part. I think they have reamer that can expand. Not to sure. The search is on.
Thanks for all your comments and suggestions very insightful
The reamers are different sizes FYI. My local machine shop that has built all of my other heads didn't want to mess with this since they would have charged me for the reamers needed to get them done.
I would NOT hone them unless you are 100% sure you are true with the valve seat...hence the reamer to make sure to get the valve guide straight after installation. Then of course machining seats to match valves.
It all can be done no problem, and it's not exactly rocket science, but I sure wanted my valves straight in my head and my machine shop agreed when I told them the motor might spin 9,500 rpms one day!
I agree that the seats have to show good signs of a proper seating pattern. I have had mixed feels about if it will be out that bad, and would need recutting. If thats the case im screwed. I can do a bit of slap seating old school style, but im interested to see how far out it will be. Lots of guys say it will be off and its best to cut the seat using the guide to center it up. But some guys say they never had to cut the seat. A good slap seating worked just fine. Ill find out sooner than later. Not to long ago i found out the reamer size i needed. About 6mm intake and 7mm exhaust. I plan on measuring the valves up tomorrow then buying the reamers
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
