Hi all,
I've got a 350Z 6 speed manual in my R33, so I'm using an S15 crown and pinion (3.692) to bring all the gears back close to standard.
This pic might explain that better, it's my current setup Vs a standard R33
578831393fb0d_350ZvR33.thumb.jpg.761c4ec
The diff will be taking some abuse once it's tuned and hitting the track, so I've lined up a 32GTR rear end to swap out.
I obviously want to keep that 3.692 ratio in the diff.
Will the 3.692 crown and pinion work in the 32GTR housing?
Cheers
When you say "got a GTR rear end to swap out", are you saying that you've got the whole rear end?  Because you will need to keep in mind that there are a number of differences in the various attachments.
GTR diffs have 6 bolt stub axles and drive shafts, so you need those and the GTR hubs.  GTR diffs use a CV joint connection from the tailshaft to the pinion, so you need to either use the back half of a GTR shaft or change the input flange on the diff.
There are some geometry/width/arm changes between early (ie 32) and later (ie 33) rear suspensions.
In the face of all that, the question of whether the CW&P will install onto the GTR pumpkin is actually much less of a problem.  In general, yes they will.  Almost all of those R200 diffs are pretty much interchangeable in that regard. For example, I have an R34 4.11 CW&P installed onto an S15 helical centre in an R32 housing.  But you also need to be aware that there are 2 bolt sizes for attaching the CW to the diff centre, and that sometimes catches people out.  Shouldn't be a problem in your case.
All in all, it would probably be better if you obtained a 1.5 or 2 way mechanical aftermarket centre to put into your original R33 housing, keeping your 5 bolt shafts and so on.  The diffs themselves are all about the same physical strength, so you're not buying much extra strength with a GTR diff, and the 6 bolt driveshafts are only a little bit tougher too.
  • Like 1
By GTR rear end I mean the diff, shafts and hubs.
I'm mainly wanting to swap to the GTR setup for the 6x1 shafts, as I have 3x2 at the moment. (Bought the 33 ages ago with no drivetrain, so the standard diff is long gone)
I was intending on changing the input flange on the diff, as I already have a tailshaft made to suit the 350Z box.
Thanks for the insight on the crownwheels, I'll sus that out before I jump into anything
That's actually a valid point!  Whilst the CW will usually bolt onto the centre just fine, I keep forgetting about those horrible diffs with speed sensors on the snout. The pinion from one of those may no fit into housing that doesn't expect it.  Best case, it goes in just fine.  Worst case, it's too long (because some of the single ABS sensor diffs have as slightly longer housing!) you might need some machine shop work.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
