Hey all,
With a couple mods on my Stag, I'm thinking I could be doing better fuel economy/power if I did some fuel tuning. Originally I was thinking a Nistune, but looking into it, I think this is probably a little premature. Honestly, not going to upgrade much more mechanically for a while - current have a catback, K&N drop in air filter, BOV, EBC. it's gonna be a while before I look at FMIC/turbo/injectors/fuel pump. That lot would need a Nistune, in my opinion, but for now I'd like to run a good clean setup at around 10/12psi.
Have done some searching and reading and it seems like some folks are using SAFC for fuel maps. But I'm wondering how people actually tune their maps? Doing it DIY on the road? On a dyno? Using a datalogger? Laptop connection? Really interested, as I can see units on ebay for under $250 but keen to know what the best course would be for tuning it. I've read about folks pulling up to -35% off the top end of the map but I'd be concerned to hit a knock at that level, without seeing an AFR data log.
Cheers
https://www.sau.com.au/forums/topic/465918-super-afc-ii-tuning-s2-rsfours/
I've had a safc neo, it was ok and made about a 1-2second difference to my 0-100 time.
A safc doesn't compare to an actual tune. An actual tune is a lot safer, while the driveability, fuel savings and power are far beyond what a safc can do.
Post a pic of your car mate! Nice to see another stagea owner around :cheers:
Because I had an auto I had an SAFC in my S1. But I also had an SITC (for timing) a Jaycar boost controller and an HKS speed control defeater so that I could exceed (on the track) the 180km speed limit of the stock ecu. Obviously this all cost more than a Nistune but that was not an option for the S1. I also paid for a tune which you need in any case.
If you have a S2 Neo engine getting a Nistune is a no-brainer. It will do much more  than a SAFC for not much more money and the SITC is getting really hard to find. You should be prepared to pay for a tune in any case so the Nistune is incomparably better.
  • Like 1
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
